discoverEDC
I installed an IMS20 into my 120P in hopes of greater throw. The end result was an increase of approximately 17% on max (partially used RCR: baseline lux = 2280, after mod 2660). The beam pattern turned out pretty good, one or two very minor disruptions at the edge of the hot spot. The was the good. The not so good is that the hot spot turned yellow and the corona around it turned blue. I'm not certain I'll be able to stand the two colors right next to each other. I'll probably put the original reflector in and wait for the V bin Seouls to come out next year and up the lux that way. Novatac did a pretty good job with the orange peel on their reflector with only a 17% loss in throw. If I could find a cheap(er) TIR lens such as used by Milkyspit to mod a 120P I would like to try that. I hope someone puts a TIR and V bin together next year, it would be interesting to see how that worked.
Just thought I would share the info.
