tino_ale
Hi all,
So far I've been using Artic Alumina 2 parts thermal adhesive.
While the end result seems ok and the adhesive does it's job, I have to say I really don't like to use that stuff.
First, it stinks seriously. Also, when I don't use it for a couple of weeks, I generally find the thickest part seringue impossible to open, potted. Last time, the mixture took ages to cure for unknown reasons (I made the 1:1 mixture normally). And last, I find it too thick : I would like to be able to inject it with a seringue (for example for Aleph LE, intead of filling approximatively the LE before closing it, I would prefer to fill it after it is closed with a seringue).
So do you guys know something that would be as good thermal adhesive but more fluid? Is it mandatory that it is 2-components or does it exist from a single tube, and will cure from contact with the air?
Thanks for your info
