Well, titanium could be extremely important if you drive your car with the top down while going over Mach 3. At those speeds, the air flow would heat an aluminum antenna up to the point where it might sag.
Titanium would also be handy if you were using your cell phone antenna to defuse magnetic detonated mines, and you needed to reduce the weight of the antenna so that you could be launched into space to do this.
