I have a B42 which I've modified with a seoul and altered the brightness settings using the 250 click thumb-knackering trick.
Up until now it's worked fine, but when I hold the switch to access the max setting, it's started to flash the SOS sequence, before dropping down to the lowest setting I have it set at.
I always use rechargeable cr123 batteries and make sure they are fully charged when I replace one - this happens no matter how much charge is in the battery.
I've had it for about a year and would hate to think it's on the way out.
Any advice/explanation would be most welcome.
Cheers,
Rob.
Cheers,
Rob.
