Interesting to watch the DBS stuff. Are the pills easy to install and use? Looks like a real flexible system that can be changed quickly. Hope the DBS does not have the <6.0v issues with primaries.
The pills change out quickly, so having an extra pill on hand is a great way to make the DBS a dual battery type flashlight.
Technically speaking, the DBS is similar to the Tiablo's, except that if you use a digital module in the DBS (2SD or 3SD), then you can (ONLY) use the 18650 battery with the digital module. The upshot of that is that the digital pills are perfectly matched for the 18650's voltage and provide great regulation and long runtimes.
With the non-digital DBS pill (2SM), you will want to use CR123's (but the 2SM can also run on the 18650), and the main reason I ordered the DBS w/3SD PLUS the extra 2SM pill is so that I can use 18650's exclusively for economy and throw, but on those occasions when I lose house power and can't recharge the 18650's, I can switch to the 2SM pill and carry on with my horded CR123's as backup.
It is that quick-change pill feature that makes the DBS a good way to go if you get both modules, but I can't say it's a better system than the Tiablos because even though either the A8 or A9 Tiablo is better run on their respective battery types, they BOTH can still use either type of battery which the DBS digitals can't.
What's great about all this is that we have so many choices among the brands, that if you end up with 4 or 5 different lights with different features, you will have covered virtually every conceiveable situation you can imagine.
I'm reasonably sure that having a MRV-SE/Epsilon, the DBS with both modules, and the Tiablo A9s, I think I'm done with accumulating any more lights in that "class".
Sure, there are others out there, but when I consider the various and different features of those three lights, I personally find that they (as a group) do everything I want in that class and more.
