Gransee
Arc-LS4
Fall 2003
Arc Flashlight is pleased to announce the latest evolution in the Arc-LS line! The Arc-LS4 adds improved beam quality, higher brightness, longer run times and user selectable levels while actually decreasing the size and weight of our flashlight.
The LS4 is scheduled for delivery in March 2004 (updated). We will not take back orders until just before the product is ready to ship.
The LS4 will include the following:
<ul type="square">[*]1W HD LED emitter
[*]1x123 cell is default power source
[*]New tail switch design provides lower profile, fewer parts and more reliability.
[*]18 calibrated brightness levels (all levels are regulated), easily selected by pressing tail switch. No complicated control sequences or "fun" functions
[*]"Find me" beacon assists in locating the LS4 in a dark room (function can be user disabled)
[*]"Safety" lock prevents the LS4 from accidentally firing while in transit
[*]"Burst" function provides ~20 seconds of overdrive brightness for illuminating distant objects or blinding attackers (duration of Burst mode is determined by LED temperature)
[*]"Ready for Service" indicator with each new battery change shows that the cells are properly installed and have sufficient life for minimum use (this limits the possibility of a rude surprise later when you need light the most)
[*]"Auto conserve" mode lowers the power setting to the next dimmer level when the battery is too depleted to maintain the current brightness setting
[*]Waterproof to 100 feet
[*]New reflector design provides for a smoother beam distribution (optimized for medium field range, similar to a low dome pattern but with better tint consistency). This also cleans up the fit and finish of the optical system.
[*]Scratch resistant Polycarbonate lens
[*]Target run times vary from ~1 hour in level 1 "high" setting to over 400 hours in level 18 "moon" setting.
[*]Will be available in 2 grades, standard ($150 list) and premium ($180 list). Premium uses a LED hand selected for brighter output.
[/list]
Prototype pictures will be posted this summer.
All posts here on the CPF by user "Gransee" are copyrighted 2003 by Arc Flashlight LLC.
Fall 2003
[/list]
