Newb here:
I just purchased what I thought was a 5 level Cree Drop in for a 6P SF.
When it arrived I installed it and there is a much larger gap betwen the bezel and the body than the original. Will the gap affect the water resistance? Also there appears to be only 3 or 4 modes that work.
When I turn it on it is on high I assume ( extremely bright ). Twisting the tail cap on/off the second time seems to dim the light a bit. The third mode is a steady slow flash and the fourth is strobe. If I twist the tail cap again the light goes out but then gives a momentary flash every 7-8 seconds.
I guess I am expecting a bit much for $12 but I was kinda excited about my first attempt at a mod.
