Luminescent
- Joined
- Jun 26, 2007
- Messages
- 399
Now that Jetbeam has introduced a new C-LE v2.0 'clicky' version, most folks can enjoy this fine light without worrying about finding a high performance lubricant for the 'twisty' threads.
If like me however, you still like your old 'twisty' v1.2 C-LE because it is more compact for EDC, you may wonder what lubricant will give your treasured light the best performance and life.
I have tried more than a dozen lubricants for my C-LE v1.2 and have found that the quality of the lubricant makes a huge difference in the performance. Almost no other lights place the demands on the thread lubricant that the C-LE does because:
A) Some are NOT 'twisty' designs, so if they do have any bare aluminum threads it's only on the tail-cap (where we don't care as much about wear, because the thing isn't getting twisted every time you turn the light on).
B) If they ARE a 'twisty' design, unlike the C-LE v1.0 and v1.2, they use an alternate design which lets them anodize the theads (My ultrafire B3, Fenix L0D, and other twisty light are ALL in this catagory and have HARD ANODIZED threads).
Because of these issues the lubricants for most flashlights are not one tenth as critical as they are is on the C-LE.
On the C-LE, using an improper lubricant can wear the threads out, and if this happens, THE LIGHT BECOMES USELESS.
So with this in mind, it makes sense to make an effort to find the best possible C-LE lubricant.
Here is a list of the some of the lubricants that I have tried and the results.
What works -
Nyogel 760G
Works well overall, not quite as smooth as fresh Mobil 1 automotive grease (which was the smoothest), but very close and unlike Mobil 1, Nyogel is colorless and doesn't have an unpleasant smell. Nyogel is also close to Mobil 1 automotive grease in giving good reliable electrical switching operation in the C-LE's twisty switch. 2 oz. is less than 10 dollars shipped at Battery Junction.
Mobil 1 Automotive Grease
This Red Grease had the smoothest operation (by a very small margin over Nyogel 760G). It also had the best overall electrical contact reliability for the C-LE's twisty switch (also by a small margin over Nyogel 760), but Mobil has a slight odor that some might find unpleasant (only really noticeable when changing the batteries). Also, because of the odor issue, there is a question of whether Mobil 1 grease has volatile components that might evaporate and condense on the optics. I used this grease for more than six months in my C-LE and did not see any problems, but the head of the C-LE has some potting compound and is pretty well sealed, so the results in other lights may vary. Mobil 1 is a good general purpose grease that you can use on your car, and around the house and a 1 pound can should costs about $7.75 at your local automotive parts store (I got mine at Kragen).
Generic Lithium Multi-Purpose Grease
You can get a tube of this stuff for only a few dollars, at a local home dealer. There is white lithium grease as well as darker brown/black compositions. The lithium greases that I tried worked quite well (close to Nyogel 760G) so if you don't want to spend the money for the Nyogel because you already have some of this stuff lying around, then it's a good bet. Even if you don't have any suitable grease on hand already, this is by far the lowest cost solution. I saw a cylinder of multipurpose lithium grease at Home Depot for only 1.95 and decided to give it a try, and it worked fine (This cylinder is designed to work with a grease gun, but you can just pop the cap off the cylinder and scoop out some grease). This grease was black rather than white, so I wasn't able to evaluate the thread wear by looking for dark particles in the grease, but it should be low, because the threads turn very smooth even under moderate pressure.
Things you can use in a pinch –
Plain Automotive motor oil (30 weight, 10W40 etc).
Turns smoothly when applied, but doesn't remain smooth as long as any of the above greases. Unlike Mobil 1 grease, I didn't do any long term testing with motor oil, and the fact that the lubrication decreases over time gives some concern about so the volatility. If the motor oil has volatile components, this creates some concern about the oil evaporating, and re-condensing on the optics. Ok if nothing else is available, but I would clean it off and replace it with one of the above options as quickly as possible.
Teflon Grease or Lubricant Oil with Teflon [PTFE]
I tried both Tetralube G (grease) and Tetralube L (lubricant oil) and both worked reasonably well, but these PTFE (Teflon) lubes did not completely eliminate the 'skritchy' rough feel when the threads were turned under moderate pressure (Moboil 1, Nyogel 760G, and even Generic Multi-Purpose Lithium Grease all showed no roughness under the same conditions). The Tetralube G grease was slightly smoother, but I did note some aluminum wear occurring. I think even the soft Teflon particles in the grease are abrasive to bare aluminum. For Fenix lights and other lights which have hard anodized threads, the extra hardness provided by the anodized surface can allow Teflon (or generic PTFE lubricants) to provide very smooth operation, but I no longer recommend them for long term use in the C-LE due to wear concerns.
Things that DON'T WORK WELL –
WD40
Much too thin to provide effective lubrication, and will attack the o-ring over time.
Dow 111 Molycoat silicone grease
This is a very thick grease, and is recommended as an o-ring lubricant, so you would think that it would make the threads of a C-LE turn smoothly, but that is not the case. This grease gave the C-LE a very scratchy feel and turned black with worn aluminum very quickly. Silicone plumbers grease is essentially the same stuff. These types of silicone grease are ok as an o-ring lubricant on plastic bodied flashlights, but DON'T use them on your C-LE unless you want the threads to wear out very quickly.
Bicycle Chain Lubricant
Most bicycle chain lubes contain a penetrating solvent, that will attack the o-ring on the C-LE (I tried Boeshield T-9). It did eliminate friction in the threads well, but the o-ring compatibility issues make it unsuitable for use on the C-LE.
Loctite Krytox RFE PFPE High Performance Lubricant
This stuff costs more than 40 dollars for a 2 ounce tube, and it chewed the threads of C-LE to bits, leaving metal particles everywhere after only a few hours use. Not recommended under ANY conditions. Loctites technical support is also unbelievably poor. When I wrote a VERY detailed complaint, indicating that there were issues with Krytox as a lubricant with soft aluminum alloys, here is a direct quote from the response I received from Loctite technical support: "It sounds like the customer cross threaded this because that is the only way the threads would have been galled. Loctites only purpose is to lock threads in plave [SIC] so it will not back, back out of whatever they are doing. It is not possible for the compound to disolve [SIC] or corrode material". UNBELIEVABLE! This is Loctite Krytox LUBRICANT NOT Loctite THREADLOCKER, and I made that VERY clear in my complaint. In any case, Loctite Krytox is overpriced GARBAGE (the generic PTFE Teflon lube worked MUCH better and cost about a tenth as much).
Conclusions -
Mobil 1 grease worked best by a small margin, but overall, I like Nyogel 760G, it's very close in performance to the Mobil 1 but is odorless and colorless. Right now a large 2 ounce tube (basically a lifetime supply) of Nyogel 760G is on sale at Battery Junction for less that 6 bucks (Less than 10 bucks SHIPPED if you use USPS shipping). This has to be the best deal in town.
Nyogel 760G at Battery Junction
On the other hand, if you have some reasonably good quality Lithium Grease on hand, and want to save some money, you can go ahead and give it a try.
To see if your grease is working well, put a small amount of outward pressure on the threads (a pound or so) and then turn them to see if there is any scratchiness. A good lubricant like Nyogel 760G or Mobil 1 will still turn smooth even under moderate pressure.
Another symptom of a poorly performing lubricant is that you will feel a scratchy stutter as the head cinches down (just before the light turns on).
If your lubricant does not show this scratchy stutter when you turn the light on, turns smoothly under pressure, and doesn't show significant metal buildup in the threads due to wear, then it's doing a good job.
What works -
Nyogel 760G
WD40
Conclusions -
