When removeing the pocket clip on the SureFire E-series, the O-ring is more exposed for damage and dirt... I am not sure how this will influence the lights water-resistance
but then again, I allways use silikon gel on my lights!
edit: I used lightemup's method to remove the pocket clip on my E-Series, be carefull not to loose the little plastic thing that probably will follow the clip out...
