I'm looking for a small light that I could attach to the side of my mountain bike's head tube to provide some supplemental close-in illumination which does NOT steer with the handlebars. This can be beneficial when climbing tricky or steep trails, where the bars end up going all over the place.
I was thinking about a light such as the Fenix Q5 powerpack special, which claims ~120 lumens on Turbo with the L1D body. However, from the beamshots I've seen, and the beam pattern of my L2D Q5, that's not the beam pattern I need for this application. I need a really floody beam pattern.
I already made a determined attempt to unthread the reflector of my L2D Q5 a little, to see if a Fenix's stock beam pattern could be softened up (as I've heard people discuss here). I couldn't move it, even with full-circumference clamping on both sections, so that's out.
So, is there an affordable AA light which has a floody beam and can run at high output for about 90-120 minutes? :shrug: Or perhaps I can find a diffuser of some sort?
Thanks in advance for any suggestions!
