Chris M.
Just recieved one of these little lights. I am very impressed - fit & finish are great and talk about bright! Brightness appears on a par with a SureFire P90 lamp, but the colour is whiter - about the same as the A2`s (yes, I got one of those too!). A full review of it will appear on the Torch Reviews Site hopefully quite soon - as I`d like to get my impressions of it online before the fuss about them dies down. That fuss being totally justified by the way! It even came in a quite nice presentation box, though the extra lamp and battery I ordered were squashed in there too, spoiling it somewhat.
But I noticed a few unusual things that I`d like to share with you all.
First: the charger. Neatly made thing, rather nice with the two-colour status LEDs, universal voltage too so it`ll work world-wide (they even fitted a UK 3 pin plug to mine!). But, oddly, both charging lights illuminate when only one battery is in place. Two lights suggest two independently monitored charging slots, but it would seem not. Better watch that - if what I`ve heard about Lion cells is true, I don`t think it would take too kindly to having one totally depleted cell in there and another only partly used, being topped up. At the least, it would mean the drained one wouldn`t get properly charged.
Second: I ordered an extra lamp and an extra battery. Both lamps and batteries are different. One battery has a silver label applied which indicates it is a 1400mAh cell, while the other unlabelled one suggests 1800mAh. I wonder which is right?
One lamp has a silver back portion, the other is gold. Both are 3.7 volt ones and both are the same brightness. The silver one fitted in the light just fine (neither were installed) but the gold one had two little nubs moulded into the rim of the reflector that prevented it from going in. Manufacturing defect, me suspects.
The reflectors by the way, are made of a ceramic material! Rather than fussing with e-mails and returns I set to the "bad one" with the bench grinder and carefully smoothed the nubs down so it would fit. This is how I discovered it was ceramic not metal. No damage done though, now it works fine. That one has a slightly tighter beam than the other one too. Old and new versions perhaps?
Incidentally the 3.7 volt lamp and LRB168 battery appear to be the same as those included in the SureFire retrofit kit on the WGC site. I tried them in my G2 but it doesn`t work. The lamp doesn`t make contact with the negative. Don`t have any other 2 cell SureFires that take P lamps to try it with. I wonder if the SF kit has an extra contact spring for the lamp assembly? Or perhaps it`s OK in metal bodied ones?
Finally, the tail cap`s LEDs were dissapointing. They look like the ones you`d probably find in those cheap LED-Club "Flushlights" (though I don`t have one of those and havn`t tried one) and are outshone by a Tektite Trek 2, two-LED light. Not useless though, and probably mod-able too. I don`t know what sort of current they draw, but I`ll measure it when my bench meter comes back from its annual re-calibration.
They might be dim, but they`re actually rather unusual. They glow in the dark! I noticed an odd green colour visible in the tail and on closer inspection saw that it`s glowing! Not sure if the glow compound is inherant in the LEDs or whether it`s been painted/stuck on to the backs of them (the latter seems more likely) but it`s quite a neat feature. The glow isn`t great, but would probably be enough to locate it in the dark!
As I said, a full review with photos, beamshots, comparisons and all will be added to the Torch Reviews Site soon (a few weeks I would suspect). But first impressions are very good. Too bad WGC-Shop raised their prices, but there`s always Pila. These would seem to be very good choices for those who`re looking for decent everyday-use rechargeable lights, and if my initial impressions hold true, I`d say they`re very good value too.
Thumbs up! /ubbthreads/images/graemlins/thumbsup.gif /ubbthreads/images/graemlins/grin.gif
