I want to try to spend under $50. What's the build quality on the JetBeams? I'd rather sacrifice some brightness to get better quality.
The Jetbeam C-LE2.0 costs less than 30 dollars with the CPF discount, and has very nice build quality. The HAIII hard anodized finish is as good as any you will find. In fact the anodized finish is better than some of the Fenix lights costing twice as much, and matches some lights costing ten times as much.
The C-LE has a high quality aluminum MOP textured reflector, so the beam is very clean.
The C-LE's electronics are second only to Fenix on efficiency and regulation and give great output and runtimes (two hours on High, 5 to 6 hours on medium, and 24 hours or more on low), which is much better performance than nearly all of the other lights under $50 that you will find.
Compared to the 1W 1AA River Rock at Target, the C-LE offers literally TWICE the performance on the same single AA battery.
For example on high the C-LE has more than TWICE the output with more runtime, on medium it has the same output but offers more than TWICE the runtime, and on low you still have a useful level of light (about like those little triple 5mm led lights), but you get an incredible 24 hours plus of runtime on a single AA battery.
It's a 5 mode light but don't worry it's really simple to change modes and the light remembers the last mode you used so most of the time you can just click the light on and off like a simple single mode light.
If you would like about the same output in an even smaller package, check out the Fenix
L0D Q4 seasonal special . The tiny L0D Q4 single AAA light has the same three power modes as the C-LE and can nearly match it mode for mode on power, thanks to a premium bin Q4 emitter (the only tradeoff is about half the runtime due to the smaller AAA battery).
This is a super deal at about 42 dollars shipped (with the CPF8 discount coupon at checkout).
I just recieved my red L0D Q4 and it really is an incredible little light.
The fact that this little light can keep up with the larger Jetbeam C-LE also means of course that like the C-LE it can BLOW AWAY 1W department store Luxeon lights like the River Rock 1W 1AA by a factor of TWO or more (in a light that is less than
half the size of even the smallest single AA light).
