Handlobraesing
Banned
- Joined
- Feb 14, 2006
- Messages
- 2,724
Through experimentation, I found that digital camera is nowhere close to showing the difference in brightness the same way our eyes see it perhaps due to limited dynamic range.
With a light dimmer, lamp and a camera with manual controls, light up something at max brightness and manually set the shutter speed & aperture, so the EV reads +2.
Keeping the camera setting the same, dim the light down until you can barely see the lit surface in camera's screen.
Compare the difference between the perceived brightness difference between two pictures and the perceived brightness difference between the two dimming levels of the actual photographed surface with your own eyes.
You'll immediately notice that the difference is far more dramatic in photo.
