Any non mag applications? I just figure if I'm going to run it in a Mag I may as well use the HO bulb.
Well, anything that takes a PR base really, but I can't think of anything smaller than a mag 2C to use it with. The advantage of the ROP lo vs hi in this application:
1. Ability to use cheap 18650 batts - protected ultrafire and trustfire 18650's can be had from DX and KD for $5 a pop or less. They are not as high quality as AW cells but, if you don't mind changing batteries every couple hours, then you can have 4 of those for less than 2 AW cells. They are thus more disposable and you would get more total runtime
2. Because of it's high current draw, the ROP Hi requires top-notch AW cells and has much lower runtime, thus the need to change batteries more often, thus the need for at least 4 AW 18650s (~$50) or AW "C" li-ions at $22 a pop.
3. ROP low bulb responds much better to glass etching in my personal experience. After etching the bulb and using in a SMO reflector, the ROP low produces a beautiful SF like beam. Not the best for super long throw, but it is great for applications out to 100m or so and Friggin Awesome for 10-20m applications where the ROP hi can be too much and wash out or leave spots in your vision if you're not careful where you shine it.
Out of all the lights I have, the 2C ROP lo gets the most frequent use just because of it's sheer practicality.
Hope that helps
-Pete
