need help deciding which one to get so id like to hear what all of you think?
i have both. i prefer clickies over twisties. for me that's the major deciding factor in acquisition order (when i can afford both out of my budget at the same time) and use.
i don't mind using a twisty like the P1-CE with only ON and OFF. in fact, i EDC one every day on a Victorinox coupling ring fob in my pocket (keys+leatherman+lights).
it's easy enough to turn the light on and off with one hand. the T20 having more lighting modes makes one-handed operation a bit more difficult. the memory feature makes it a bit easier to use, but often i don't want to use the same light level as was last used previously. twisting multiple times within a short time period with one hand, while NOT overly difficult, does sometimes result in "mistakes" since i'm a bit of a klutz. hopefully, you will prove to be more skillful if you go with the T20.
for me it's far easier to click the tail cap multiple times than to twist. the fact that TURBO mode requires a separate twist is largely a non-issue for me. i rarely use it. however, if one requires more of a tactical light, then simply twist the bezel before needing to use the light, so that when it requires rapid deployment it is already in TURBO [+STROBE] mode and only requires a single click for TURBO and a half-press following this for STROBE. simple solution to a simple problem.
if less light is needed, then it's probably NOT an emergency situation and you could easily twist out of TURBO mode back into GENERAL mode before clicking the tail cap. the extra two seconds in this scenario is NOT life threatening and easily accomplished with no duress.
T20 has a wonderful beam pattern though. Also has one additional o.p. (output) level which i find useful for some applications.
all that said, the Fenix P3D-Q5 is my preferred choice - mainly b/c it's a clickie.
the P3D-Q5 also becomes a very different light with much longer burntimes with the purchase of the Fenix-Store 3xCR123A custom body. if you think that you'd be interested in such an upgrade, to my knowledge at this point in time, it only exists for the Fenix light, and not the Olight T20.
if you only get one, you really can't make a bad choice. they are both fine lights.
hope this "take" on the two lights helps some in your selection process.
