I have a an XRE in one of my flashlights that runs slightly under 1500m(About 1450).It gets used every day on average of 20 minutes a day and it is still going strong after almost a year. The Q4 in my Super Thrower is running at 2As and has been doing so for about 6 hours all added up. No sign yet that the leds output has degraded. And I have been monitoring it with a light meter.Just wondering how much they can take and how long they will run at 2A or maybe 1.5a would be better before and is a single 18650 capable of feeding a 2A draw.
Thanks,
Matt
It will last long enough. I highly doubt anyone here has ever used one of their flashlights for 50,000 hrs. Multiple emiters will put out more light when ran at the same total watts but they will not have the same throw if using the same size flashlight.Not nearly as long as a pair or even 3 LED's being driven total at that wattage. If you have the space, multiple emitters will last longer and be more efficient. Honestly Lumen maintenance is pathetic at best when severely over the rated current, so you will get large output drops in short amounts of time.
I read that someone on the DX forum (saabman) successfully hooked two in parrallel
You tried putting one AMC7135 board in parallel with... an LED? :thinking:It doesn't work with all drivers though. I tried it with one of the 7135 boards and nothing happened.
No. Of course not. Thats crazy talk . I used two of the AMC7135 1400mA Regulated Circuit Boards in parallel with one LED.You tried putting one AMC7135 board in parallel with... an LED? :thinking:
One of these boards (http://www.dealextreme.com/details.dx/sku.3256) in parallel with an AMC7135 board?
If you had them connected properly, do you think 2.8A could be the reason "nothing happened"?I used two of the AMC7135 1400mA Regulated Circuit Boards in parallel with one LED.
Again, crazy talk. They are only 1400mA if you make the right connections on the driver. I did not do this. If memory serves I tried it with them both set up to give 1000mA each. And I used that same LED right after that with the other drivers so I know the LED was OK.If you had them connected properly, do you think 2.8A could be the reason "nothing happened"?
So you weren't actually connecting 1400mA boards to the LED in anything except name. :shakehead And you didn't instaflash your LED after trying to feed 2.8 amps into it.Again, crazy talk. They are only 1400mA if you make the right connections on the driver. I did not do this. If memory serves I tried it with them both set up to give 1000mA each. And I used that same LED right after that with the other drivers so I know the LED was OK.
I just said which boards I used. That is their name. That post was not intended to be an in depth reply about the AMC7135 boards. All you need to know is it does not work. Give me a little credit for knowing the difference between a bad driver setup and a blown LED.So you weren't actually connecting 1400mA boards to the LED in anything except name. :shakehead And you didn't instaflash your LED after trying to feed 2.8 amps into it.
Did you ever think it might be easier to just explain what you were doing?
Great, I've misunderstood you again, then, because I thought you said you hadn't connected them properly. But if they were connected properly I don't see what difference connecting three or four of them in parallel will have to connecting six in parallel, apart from the total current. The AMC7135 does work in parallel, and hence the 700mA, 1050mA, and 1400mA boards. Do you have any ideas yourself why you were unable to get them to work?All you need to know is it does not work. Give me a little credit for knowing the difference between a bad driver setup and a blown LED.
Like I said, I don't see why it wouldn't work, so I'll give it a go a bit later. Does a single AMC7135 on each of two boards sound OK? I think that would prove the principle.If you think you can make two of these AMC7135 boards work together please let me know how you do it.
You're not the only person looking for such a board. (I've chimed in on the odd driver search thread recently.) I haven't seen any other suggestions. But if you don't mind a bit of soldering I had the idea of using a Kennan from KD and replacing the set resistor with three different resistors operated by a multiposition switch. It would give you three different fixed-current settings plus off, and cope with anything from about 5V (to drive an LED at 3.6V) up to 18V.does anyone know of a board that would offer similar features but a higher voltage range?
You mean you don't, right? :sigh: (Or are you arguing the toss about whether it's current or voltage that does it? )You don't instaflash LEDs with high current.
