Just got a Fenix P2D Q5.
Question: Are all Q5 still high Vf in general? Asking because battery life is important.
Anyways, compared to three other P2D Rebel 100s, the Q5 is:
1. SEEMS a bit brighter on Turbo, but dimmer in low. I did the ceiling bounce test and I thought that the Q5 is clearly brighter by a tiny bit.
2. Looks to be perfectly white. REALLY white. Obviously cooler coloration than the Rebels which may give better depth perception. Still, the 'white' is great.
3. No color tint shift whatsoever in all four brightness stage. Rebels all have some tint shifts from low to high - some worse than others. I found one Rebel that is very minimal shift but it is still there.
4. No flash whatsoever on low. Interesting.
5. The primary drawback - the Q5's beam is no where as smooth as the Rebel even with OP. Rebel just seem perfect beam spill - no rings whatsoever.
In wonder if Fenix fixed the Flash and made the low lower?
Thanks,
Mo
Thanks,
Mo
