nMotion96
I dunno if anyone tried this before. I used this stuff called plastic dip. I used the dip version to seal battery packs that i build. There is also a spray version that i used to spray the body of the flash light. This gave the light a rubber coating that gives it a not slip surface to hold on it. I only tested it out so i only spray the body so far. It works really well and doesn't scratch off. But when you need to you can peel it off pretty easy. It will also protect the finish from scratches also. Comes in a few different colors to chose from.
http://www.plastidip.com/
picture of my plastic dipped fenix p2d q5
http://img.photobucket.com/albums/v380/nmotion96/temp/DSC00001.jpg
