Lightraven
- Joined
- Sep 2, 2004
- Messages
- 1,170
Everybody has at least one tactical flashlight, right? So how about some tactics to go with that light. Nothing here should be of value to criminals.
Tactics aren't just for soldiers and cops, but anybody who might have to protect themselves, others, or property. The tactics should be realistic, though.
The first tactic is to decide when, and when not to use a flashlight. If you are in a lighted area and can be seen, there is little reason not to use a flashlight to see what is in dark areas around you. For example, looking into a drainage tube during the day. You are totally visible to anyone inside the tube, but you cannot see inside. Use the light.
If the bad guy is not believed to have a gun or other range weapon, you don't want him to approach you unseen nor do you want to approach him without seeing him. You want light to see him from a distance. Use the light.
If the bad guy may have a gun, and you are concealed by darkness, you must be more careful in using a light. Use your ears more and listen for coughing, talking, whispering, movement, prying and breaking, or other noise. In Silence of the Lambs, Jodie Foster hears the click of a .357 Magnum hammer **** behind her head and she turns and empties her gun instantly. That is fiction, of course, but I've heard of similar real life examples.
Try to position yourself to observe lighted areas (streetlights on a road or moonlight on an open field) or areas that would create noise moving through them such as a rocks or dry branches on the ground or a yard with a dog in it that will bark at noises. Observing a door may give you warning when it opens.
There are more active ways to see your surroundings without being connected to a light. Turn on a light switch. Toss a durable, wide area light into a dark area. The Lumapower M1 Tactical with bezel and reflector removed and a pullcord tied to the tailcap is something I've experimented with. Send in a dog to find people. Or deploy pepper spray (fog, mist, or powdered) into a confined space like a tool shed to see if you get any sniffling, coughing or sneezing from somebody hiding inside. I wouldn't do this to an area I was going to enter or to an area where friendlies might be, though.
Obviously, some police and military may have access to helicopters, robots and night vision gear, to add to the other tactics I've listed. The Generation I and II night vision gear isn't nearly as good as Generation III, but it works at close range in the right conditions. For police and armed security, spending a few hundred on a Gen II nightscope might be better spent than yet another expensive flashlight.
The idea is to find out who is around you and where they are without using a light connected to you. Once you gain this information, you could stay hidden, move away and call for help, or confront them (ideally from behind cover)--with or without a flashlight. You should only do the latter if you are armed (with a gun for U.S. residents, another weapon for countries where guns are difficult for criminals to obtain). An unarmed, or lightly armed homeowner or security guard has nothing to gain by lighting up a gang member spray painting a wall and getting shot in response.
