I added a regulator I made from a Maxim 1795 to my Tikka. I t seems to work rather well. It drives the led's a bright as 3 new batteries for a long time. while only using 2 batteries. I have not done any rune down tests but it will continue to work down to .7 V on the input, Though it starts to fall out of regulation soones and gradualy starts to dim near the end. At the verry end of the batterys life it is rather dim and it starts to pulse (Flashing off momentarely). Originaly the light drew 170MA and used a 3.3Ohm droping resistor. I removed the resistor and set the output of the regulator to drive the LED's at roughly 150MA.
The only wierd thing about the mod is the original switch switched the negative battery terminal, so I hade to go with it. switching the ground to a regulator is not the Ideal way of doing things. As a result the regulator does not turn all the way off when ground is un hooked. As you can see the lights stay on slightly but it only draws 50uA from the batteries. It is not a significant enough drane to cause a problem. But is dous add a nice feature making it posable to find your light in the dark.
I have always wanted a regulated AAA based headlight. I solved my problem /ubbthreads/images/graemlins/blush.gif
