One of my orders from DX came today...this light in fact..
http://www.dealextreme.com/details.dx/sku.4201
the first time i turned it on, it worked okay, then i turned it off and set it down to play with my new 30mw laser green laser..
when i picked up the light again, it didnt work, didnt turn on. I took out the battery, and replaced it, as i was screwing it in, the switch was on, and it went bright, then as i screwed further, it went dim again. It is now at the point that when i press the two parts together so that its just touching, the light is bright, normal. When i screw it in even a tiny bit, its goes dim, or goes off completely. AND, the battery heats up to the point its actually too hot to pick up....i have cleaned the threads, and done everything i could possibly think of, even look at the clicky.
the light only works when barely touching, something like this
This is the usual output...
this is the diminished out put that i assume heats up the battery,
the pill inside the head
the body, and you can see the spring thats connected to the cliky
the cliky
I am utterly clueless as to what on earth is going on...it doesnt make sense
...HELP!!!
Incidently it uses CR2 batteries.
on the plus side my SMJLEd came today, solitare being used to to light up this picture....
Crenshaw
the cliky
...HELP!!!
Crenshaw
