missionaryman
After reading Lux Luthor's tests on the ROP high bulb I decided to try driving my well used 3854H bulb into 8.6v territory with 7 5000mah C cells and it worked without flashing, the claimed output is about 2000L less reflector losses. The big C's don't sag under the nearly 5amps and the only resistance is in the switch that I can feel heating up in my hand.
So on a proof of concept it worked now to find a host suitable for such a venture...
I'm pretty much over modifying Maglites - I like to be innovative as much as I can be so I had this vintage host laying around that I couldn't think of an appropriate use for. It has a 4.5" faceted reflector - that's right two-and-a-half times the size of a Maglite head - 25mm bigger in diameter than Fivemega's biggest offering and sporting a modular body that can be configured as a 3D, 4D, 6D & 7D.
As you see it now it's 6D carrying 7C's but soon will be 7D carrying 7D's for 2.5hrs run time on high. (that's if the plastic reflector didn't melt so damn quick...)
Here's some pics
Beamshot in daylight - it's actually white, very white. Night beamshots to follow
Here's some pics
