Spence
I stumbled onto another idea while at "Bass Pro" that really worked out cool. I bought a package of "Bill Fisher, Size 4, ct. 4, Ball Bearing Swivels, 150 lb. test". I use one in between my lanyard, micro clip and the small split ring on the light's lanyard ring or split ring on the SF pocket clip. (My digital camera went belly-up or I'd send you a photo), I think you get the idea. Anyway, the swivel keeps the lanyard from ever getting twisted or tangled with the light. Regular, inexpensive, fishing, barrel swivels will also work, after you remove the hook/clip, but not nearly as slick as the costlier, ball-bearing swivels. Be sure to have handy, a pair of needle-nose pliers, and a flat point, micro screw driver to pry open the small split rings.
Good luck.
Spence
:naughty:
Good luck.
Spence
