bluewater
Some of you might remember the Lambda Micro Illuminator. The original AAA luxeon light...it even had a clicky!
The 1 watter was an "R" rank at a time when they were unheard of!
I managed to screw mine up when I removed the emitter from the board. My soldering is very poor as you can see.
The light has never been the same.
I need suggestions on how to update this light. Can I simply solder a SSC in place of the original lux?
Are there any "pills" made that might fit in place of the original. One of my complaints with the original light is that
it was engineered for runtime over brightness. A new pill with a higher drive current would be an improvement.
