Cavelightchris
- Joined
- Dec 5, 2007
- Messages
- 69
It wouldn't be the most efficient idea on power, but you sure could put allot of LED together in a small space and not have to worry about them over heating.
I figured you could build one yourself by buying a copper heatsink, drilling like 8 holes through it, and running a tube that zigzigs through it, and run that to a fishtank pump, and create a separate reservoir for the water. Wouldn't it be cool to make the whole thing out of copper, and even add a few copper heatsinks to the outside of it next to where the water is stored. Maybe you could run the tube outside of the flashlight and through all of the heatsinks on the outside so the water passing through it is at least being cooled to the temperature outside.
If you know of where to do this, or if you know of any lowrider type guys who can do gold plating, you could get it gold plated on the outside when your done, then it would be even better at dissipating heat, hence why they covered the 1 million dollar Mclaren F1's engine and exhaust system in gold.
If you wanted you could just buy a watercooled CPU adapter for $40.99, and then buy a pump for $74.99.
Wouldn't it add some mad bragging rights if you went ahead and added a radiator to it, this thing is starting to sound like a car. It would work enough like one that I would pour some water wetter in to the reservoir since it has even better heat transfer properties than water or antifreeze. As long as your adding a radiator you might as well slap a fan on to it, ya know..
This brings on many more ideas, how great would it be to experiment with over boosting a LED with a liquid cooled heatsink. Maybe you could make your own switch with lots of boost options: normal mode, icewater mode, and who knows maybe dry ice would work, or you could try mercury, ha ha.
I really would love to make a light like this one day, it would have to be see through with clear tubing, so I can add some florescent marker stuff in the water, and install a small blacklight.
I hope I didn't get too carried away with this article, so has anyone ever made a light like the one I'm talking about, or anything even remotely similar? Please post me a link if you know of anything like this.-'
Sincerely,
Chris
Sincerely,
Chris
