BillG
i bought a used cr123 body for an L1T v1. decided to see if it would fit my L1P head and tailcap. it does and it works great.
do you think i will damage the led in the L1P by using 3 volts instead of the 1.5 volts that the light is designed for?? BTW, the switch in the cap is one i bought from 4 sevens that turns it into a 2 stage light, using a resistor. it also works great with the 3volt CR123.
thanks.............Bill
