That kinda hardware would be WAY more expensive than is reasonable to produce. Better to just modify the stock assembly and save a boat-load of cash.
Shane
I disagree. How big is this boat? I'm not asking for PWM softstarting and all that other stuff like a Willie Hunt LVR to be squashed in there. Just a simple aluminum housing with a switch in it that is pushed off to the top or bottom a little to allow the allen key to be inserted to tighten the ground screw and lock in the switch. A shelf on the bottom of the housing could hold a hi temp non conducting ring with a central brass positive contact. Then a ceramic bi-pin socket could be screwed to the top. Only part I cannot envision is the switch, have no idea on the size of a switch capable of 24v and 10A.
So let's see, we have (1) the housing with a big hole on one side for the switch, a small hole on the opposite for the pointy screw from the mag switch. At the top are two threaded holes to mount the (2)ceramic bi-pin holder, and at the bottom is a shelf to hold the positive contact rig. (3+4)The positive contact rig is a brass button located concentrically (sp?)inside a non conducting heat resistant ring. (5) A switch, no idea on it's size. This is the hinge that closes the door on my idea, if there is a switch that can handle 24v and 10A that will fit in this space and be reasonable priced, then we are good to go. 5 pieces by my simplified count. If I was any good at drawing I'd make it graphically appear for you but alas I am not so skillful.
Feel free to email/PM me Leef to further discuss this idea.
When it's all said and done, I'd rather have a Leef
