Other than the use of a AA battery these lights are nothing alike. Since you already have the DI, I'll tell you a little about the Proton Pro (PP from now on) and you can decide if it is still what you are looking for.
The PP is quite a bit smaller than the DI and weighs less as well. It has a smoother feel since it has no knurling, but is still very easy to grip because of the ribbing along most of the light. The beam pattern is very different as well. It has a smaller hotspot than the DI but is more intense. It also has a very obvious ring around the hotspot since it uses a smooth reflector. The tint on my specific unit looks white by itself, but compared to the DI it looks quite green. Some may like this aspect of the light and consider it "warm". I guess this is just personal preference.
The PP has no memory mode at all. It turns on in its highest white setting if the side clickie is clicked the released, and turns on in its lowest red setting if the side clickie is clicked and held. After that just hold the tailcap to either decrease (white) or increase (red) the level of output. The DI has a very low level of output on its lowest level, but the low level on the PP is even lower! My lightbox registers a 10 for the lowest level on the DI, and a 3 for the lowest level on the PP. That would make the low level on the DI around 2 lumens and the lowest on the PP around .6 lumens. The red LED on the PP can be so low that it doesn't even register on my lightbox! Honestly it is probably dimmer than the LED on your Televisions remote control. On the highest setting of the red LED it is around 4 lumens or so, and has a pretty ugly beam. This doesn't matter much in real use, but if you are really picky it will bother you. In terms of overall output on their highest setting the DI gives the PP a pretty good beating, which is expected since it uses a Q5 and drives the LED a bit harder. My DI registers a 510 on my lightbox, while the PP only is a 316 both on Energizer Lithium cells. That would make the DI around 102 lumens and the PP around 63.
I would give the nod to the DI in terms of regular EDC, but the PP easily wins if you are planning on going hiking/backpacking and need a light that can last nearly forever on a single cell, and preserve your night vision if need be. I really like both lights and am glad I own both of them. If you really have to think about it this much... I say you buy it! :thumbsup:
