mule excitement
yaesumofo
Eastern Pacific, LAX DM03 sw actual
Today was a cool day. My wife received a Mule of her own directly from the mule master Don himself. Thanks Don.
Before this happened I had decided to make my wife a mule from spare parts. A Cpfr was kind enough to give me a black aleph mule head surplus to their needs. So that also arrived today.
So along with my first Mule a oil can Mule with a Nichia emitter driven at 280 ma..single level. I now have a Black mule head which is now at home atop a stock aleph single cell body and clicky. In fact this is the Aleph I bought which was the very first Cree flashlight available that I know of it came from the shop. Basically I switched out the head from the stock Aleph (CREE) head and reflector with a Aleph Mule head. So as it is now it is a pure Aleph mule. and it is very cool. I think it needs a two level switch. More on that later. Now it was not a direct to aleph approach that I took. I pulled a whole bunch of aleph and surefire bits and pieces out and have been playing all day with it. Wow what a waste of time!! no really. I tried a bunch of different bodies In the end the best looking and most functional is the aleph. In a close second is the Vital gear VG1(I think) because it has all of the same pluses that the aleph has and is a little smaller.
I have chosen to go with the aleph configuration because it works and it totally matches. I have taken a lousy image for you to look at ...Like you need to see one but there may be somebody new who hasn't seen one of these before:
Here is the business end:
I am of two minds about this. While I like the idea of a carbon fiber or glow or agate disk here There is something really revealing about seeing the raw emitter board. Most people never look and have no real idea what a cutting edge LED even looks like. You know like a watch with a sapphire window back so you can see the works? Well I sort of look at the Mule head like that. I added a glowing O-ring It fits perfectly and will help to find the light if dropped while on and it somehow magically switches off in mid air in the dark. At least with the glowing O-ring you have a slight chance of finding it under those specific conditions.
Besides the after glow is cool.
I thought about mounting an tritium thingy on the driver board. At least it will always be able to be found and the aleph window will protect the tritium thingy. Pretty good idea NO?
So in order to perfect this light I think I need a 2 level switch or a multi level driver. The 3 level unit the shoppe is selling seems to always be out of stock and a bit no very pricey for me anyway.
Ideas for a modded 2 level clicky are welcome.
OK that's it this boring post is now over If you stuck with it for this long I salute you. thanks and have a great day.
Yaesumofo​
Kiessling
Old World
Aren't there some bizarre shapes of tritium thingies around? There certainly is room in that head, and it could be freaking awesome :cool:
Agreed on the bare look btw ... The ti Mule will be left bare and techie geeky .... :D
datiLED
Atlanta, GA
Very cool. I like the utilitarian look of the light. It is very "down to business", and looks like a light that will get a lot of use.
yaesumofo
The other idea I came up with today is to make a clear epoxy disk and imbed 3 or 4 of the tritium bits into it so it would show the guts and have the glow of the trit....Hmmm
Yaesumofo
PatS
Georgia
Will the 2 stage McE2S switch work in the mule?
If it does, I will probably order this and the NG 750 CREE LE.
The shoppe has both of these in stock, at least right now.
I am expecting my Mule to arrive any day, and need to get a light engine for it.
yaesumofo
It will work if you mount the aleph mule head on a single cell aleph body and then mount the 2 stage switch on that set up.
I have no idea if the 2 stage switch can be mounted insted of the clicky which is installed in the aleph mule don is selling. Since the switches uesd in the aleph mule Don is selling are clickys, the 2 stage clicky may be a better choice, I do not know if it can be mounted as a replacment for of the stock clicky I assuem it can be.
Yaesumofo
JohnTz
chicago
yaesumofo, did you ever build a clear disk with tritium inserts on it? Just curious to hear if it worked. I am thinking about the same thing for my new oil can mule from Don. I wonder if something like that would fit in front of the GDup LE and the lens.
yaesumofo
No the tritium lites disappeared enroute along with $20.00 I sent.
I am looking for some more of them but as you may know the small tritium inserts are hard to find.
I have developed a new technique which I think blows away epoxy for the job.
I made a mule disk which glows in the dark with the stuff.
Have a look at the Hi tech materials thread I just created for info on that.
I have an idea which I know will work really well. All I need is a couple of tritium inserts.
Feel like donating a couple to the cause? If you do I will make one for you.
The idea is to use this Liquid Polymer clay stuff I found. It accepts a pigment but normally finishes hard and clear. so holding tritium inserts is easy.
I would want to mount the inserts to a carbon fiber disk with the polymer stuff. Anyway I know it will work. I just need some new tritium.\
Yaesumofo
yaesumofo, did you ever build a clear disk with tritium inserts on it? Just curious to hear if it worked. I am thinking about the same thing for my new oil can mule from Don. I wonder if something like that would fit in front of the Group LE and the lens.
JohnTz
chicago
O.K. I will try to find the tritium. What dimensions do you think will work for the inserts?
0dBm
(New member here trying to learn)
How is the power supply electrically connected to the LED in the photo below? Is the underside of the LED connected to the top side?
schiesz
Lees Summit, MO
Yep, the Cree LEDs such as this one have the contacts on the bottom. They need to be re-flow soldered to the board. There were some people that cut a corner off the emitter package and connected to something under the 'cut' when these first came out, but I haven't seen that done for a little while.
Under the board shown here, there is typically a converter board that supplies the power. This is all packaged in a Aleph XR can, that can be screwed into various Aleph lights interchangeably.
schiesz
JohnTz
chicago
Still no small trits. The smallest I can find so far have been the 6mm ones. I'm still looking.
