Kraid
I previously posted in another thread. But the title of that thread wasn't directly related to my question. So I thought I'd make a new thread.
Trying to install a McClickyhttp://theledguy.chainreactionweb.co...roducts_id=791 into an UltraFire WF-502D https://www.kaidomain.com/WEBUI/ProductDetail.aspx?TranID=1256
I've boosted the height from the rubber part so that it will unclick after you click it. And I tried bending a piece of wire so it would contact the two plates on the switch and the inside wall of the tailcap body. It wouldn't even turn on that way. I tried taking the metal washer out of the bottom of a L2D's tailcap but it wouldn't fit past the top part of the McClicky. It was making contact with metal on the top of the McClicky so I screwed the tailcap it. The light came on, regardless of clicking the clicky.
If I could buy a bigger washer that fit over the top down to the contact plates then put the plastic retainer ring back in, would that work?
