Re: HuntLight FT01X XR-E SE Upgrades?
I own them all, so let me clarify the matter for you. The SE and PJ refer to the finish with the former being HAIII, and the latter being type II. There are really two models of the FT01X that are different. The XR-E CREE has threads holding the module in place making it difficult to simply drop in a P60 module. The LuxIII-U bin model works great, and I have used P60 Q2 modules from Supertactical, SSC modules from DX, and 3-mode Q5 modules from Dereelight in this host. Don't worry that they don't have the plastic plate at the bottom of the module. Lighthound recently had these on clearance for only $24.49 including shipping, so I bought a number since they were HAIII, had AR glass, hold protected 18650 cells, and also had other nice features like a retaining ring holding the lens and o-ring in place when you change the P60 module. The HuntLight has a reverse clicky, but the multi-mode Dereelight designed to work with a forward clicky still works fine. After the Dereelight CL1H, the Huntlight FT01XSE (LuxIII-U bin) is my second favorite host. Remember that module voltage ranges from a max of 4.2V (Dereelight) to 18V (one DX CREE), so don't use 2X16340 with the former!
