F
fotzepolitic
Guest
Are these\"flashlights\" really better than candles?
What are the benefits & disadvantages between a 4AA flashlight vs. 2D? If both types are made the same, will one type be brighter than the other or last longer, or is the difference entirely dependent on the design of each flashlight? How about 4AA vs. 3D or 4D?
What about Krypton vs. Xenon bulbs, is one type "supposed" to be better?
n.b. I tested the Xenon bulb from a 4AA Garrity (Stainless Steel) against the "White Star" Krypton bulb from a 3D Maglite. I thought the Xenon would be brighter, but didn't find great differences between the two, except that the Krypton was a bit brighter.
I considered buying the Garrity 4AA over the 3D MagLite, because the Garrity threw a wider beam, and was much lighter and more compact than the 3D Mag, and no less brighter. The package said the stainless steel body was stronger than an aluminum body (obviously a reference to the competition for this model, the MagLite). Within10 minutes of using the Garrity, I dropped the plastic tailcap into the bathroom sink (by a height of about 6"-10"), and it cracked. The MagLite won by default.
My intention with all of this is to fit the single LED bulb in my Dorcy into a (relatively) compact flashlight body that will produce brighter results. So far, the only thing I've tried that was brighter was a 5D MagLite, but it was too heavy and hard on the wrist, and I'm not sure the Dorcy's LED will survive the power of 5D's over the long run, since it was designed for 4AA (so maybe it was brighter simply because I was overdriving it?!).
