Hi guys i am new here, "santza" from Helsinki Finland. Now i am asking some help for start. I have magled 2d, lots of varta 2100mah nimh ready2use AA:s, and size of 2 D cells battery holder for 6 AA:s that gives 3.6v on nimhs or 4.5v on alkalines.
First of all, I live in finland so shipping something from usa to here will cost a lot and there is also presumeably 22% VAT added so we´ll forget that. I'm looking for some easy mod that would improve beam performance vs. stock magled that i am running in 3.6volts nominal (works great altough). I tried already HPR53 4V, 0,85A halogen bulb that is rated at 60 lumens. Well that sucked a lot. original 2d krypton on nimhs was actually better, even when I used fresh 1 day off the charger 1,35V measured nimh:s
Any ideas? I need both, flood and spot beam. original magled's focusing abilities are not enough for me (the flood blackhole on center you know)
Maybe some kind of diffusor/lens that can give both good flood and spot beam? Or a decent high effiency bulb? I'd like to use the original magled module and battery holder mentioned above because it works so good.
I have also access to all original maglite spare parts because i run electronics department in a department store and we sell maglites.
sorry about probably bad language ;P
