Christoph
I just finished a new transformation combined a Bad Boy 750 with a custom made heat sink and
a 5 watt HD white and installed it in a brinkmann nexstar AA. I have been planing on using CR-
V3's split to power it, but by accident put in two AA's and found that it powered up the light
almost to full brightness.The measurements I took were :with the AA 2.6v under load 6.3v at led
with250ma draw. With the cr-v3 5.9v under load 6.8v at led and 1.2amps draw. These
measurements were all taken direct in series with the loads, so they may not be a very accurate
picture of what's happening. The light body does very well at sinking the heat .However it does
get rather warm with extended run times. With 1800mah nimh's I get almost 30/40 minuets run
time at almost full brightness before it starts flickering I haven't tried run time with the cr-v3's as
they are very expensive and the light would have to sit on an ice pack or kept moving to help the
heat dissipation. Sorry I have no digital camera the but heat sink is a 6.8mm x18.3mm disk with
a 14.8mm x5mm recess machined into the back to accept the BB and a little silicone holds and
protects it. The sink provides a wide path to allow heat to go into the heavy flashlight body.
Which parts am I stressing while running this off of 2 regular AA's(3v) the circuit or the
batteries? Am I hurting either part? /ubbthreads/images/graemlins/frown.gif
Should I / Can I run this combo on AA's or stick to the 6v cr-v3's?
More to come /ubbthreads/images/graemlins/grin.gif
Chris
Chris
