Illuminated
I bought some of those S-ranked Nicias from AB recently and thought I'd try them out in my PT Matrix module.
Getting the module apart was the hardest part. I used a jewelers' screwdriver and carefully pried the lexan over the catch tabs.
Pliars were used to unscrew/remove the drive-screw battery contacts that hold the circuit board in place.
Removing and replacing the original LED's was not too much of a problem for a person with reasonably good soldering/ circuit board skills.
The results, while not dramatic, I believe are noticeable. Since I don't have two of these modules to do a side-by-side comparison with, it's harder to quantify the improvement.
I think it now has a slightly tighter beam than before and it seems to throw farther. The center spot seems a bit more concentrated, and is noticeably bluish just as it was before.
While not the brightest LED light available, it is voltage regulated and will run at (relatively) constant brightness for many, many hours from just two cells. BTW, it will run on a single cell - albeit somewhat dimmer than on two.
In summary, this mod improves the performance marginally without affecting power consumed whatsoever. I'd say it was worthwhile.
FWIW - John
FWIW - John
