Drewfus2101
-Mag 2C, Pewter, just taken out of the package
-UCL
-Kai MOP Cam/Camless (cam is installed) Aluminum Reflector - no plastic reflector to melt.
-Mag C Tower - don't worry about melting the stock plastic bulb holder.
-2 x 18650 Trustfire Protected (2500mAh) *included*
**These batteries fire up this ROP High bulb on the FIRST click 99% of the time.
-ROP High bulb - This is the first light this was used in
-ROP Low bulb - Tested and does work
-Mag Ring 2 Kit (18650 Battery tube, Lanyard/extension ring, tail-cap connection)
Also included is 1 small magnet that is needed between the batteries. Everything that is needed is included. The batteries are even charged. Just pop them in and go.
Based on LuxLuthor's calculations on the ROP-High bulb, it is capable of putting out just over 1900 lumens. However, when using 18650 batteries, you experience voltage sag under load. That along with some small estimated losses in the stock mag switch (no tail spring = no loss there) would lead to a lumen output estimated (by someone much smarter than myself) of just under 700 lumens.
I also had a chance to test this in my light box. It read dead on 5 times brighter than a Mag with a P4 driven at 1amp.
Based on the maximum amp pull from the bulb (4.8 amps), battery life should be right at 30 minutes on these fully charged batteries.
PICS:
You can see where I put a solder blob on the switch + connection where it meets the batteries. This way you don't need to use a small magnet that could move and short with the side of the body.
The body is perfect.
Battery shots:
Mag Ring 2 tail-cap setup:
-No flash, manual settings, manual focus. Just to show how smooth the beam pattern is.
Same as above but with flash:
http://img246.imageshack.us/my.php?image=pic08ya4.jpg
http://img246.imageshack.us/my.php?image=pic07uo9.jpg
$175 -> $165 -> $150 -> $135 -> $115 shipped Con-us, others add $15, paypal only (credit card add 3%)
EDIT: Only selling to get rid of spare parts laying around and fund other projects.
Night beam shots to follow.
-UCL
PICS:
Battery shots:
