madecov
On the Deree CL1H
The 2SM and the 2SD
Both seem to be 2 stage lights. I'm guessing the 2SM is click once for low and a second time for High.
The 2SD instructions on the Deree web site are less than clear.
If I turn on the light using a momentary use will it start to cycle?
I use both momentary and constant on a regular basis, I will be needing a two stage light as I will be changing assignments and a lower setting will be useful.
The 2SM and the 2SD
