Gearhead Jim
- Joined
- Apr 20, 2006
- Messages
- 20
For several years, my pocket light has been a SF G2 Nitrilon. Looking to get the slightly brighter light and much longer runtimes, I just bought a 60L module from SF. Tonight I did some testing, and the 60L simply does not give me the distance of the old P60. We live in the country, with little surrounding light. 52 yards from my back door is a tree line, and a 8" x 16" target that is painted black with natural wood circles of 4" down to 1".
With the P60 module in my unit; the target does not jump out at me, but I can see it if I look carefully, and can barely distinguish the 4" circle.
With the 60L module; I simply can not find the target even though I know where to look. It also seems that I can't see as far into the trees, but that's more difficult to judge.
The testing was done with the same G2, batteries, etc. The only thing changed was the module, and I switched back and forth several times to be sure of my results. The 60L module was checked within 15 seconds of being turned on, so heat buildup should not be an issue.
This is pretty disappointing, can anyone explain what is happening?
Also, what wouold be the run time down to 50% brightness in the 60L, with the SF brand batteries? I don't believe that 11 hour stuff now.
