GOOD NEWS! Your Inova X1 Gen. 2 is NOT dead!
The failure is a result of the flashlight being dropped on the LED end. This causes the front gold plated contact to be jammed forward by the battery nib and getting stuck in that position.
The quick fix for this is to first remove the battery, then insert a piece of ½" wooden dowel at least 6" inches long in place of the battery. While holding the dowel in place, position the flashlight so that the LED is facing up and the lower end of the dowel is 6" above a tile or concrete floor - not carpet! Now, while holding the flashlight in your fist, SLAM the flashlight and dowel assembly into the floor - REALLY HARD!
The flashlight should now work. :twothumbs
However be aware that the problem will re-occur should it be dropped as described in the beginning of this post.
