MomentOfBrilliance
- Joined
- Feb 26, 2007
- Messages
- 1
Okay, this question might be a little confusing, but bear with me.
I've been reading on the forums here that the Streamlight Scorpion can be easily modified by replacing the lamp with a TL-3 lamp and using two RCR123a's (which appear to be 3.7v) or two RCR123's (which appear to be 3.6v).
My first question is: Which of these is the correct set of batteries to use for the Scorpion mod: the RCR123a, or the RCR123?
My second question is: I have an Ultrafire Multi-Battery Charger (http://www.lighthound.com/index.asp?PageAction=VIEWPROD&ProdID=2566) that says it is a 3.7v charger and can charge RCR123's. The confusion here is the fact that RCR123's are 3.6v (not 3.7v) and that RCR123a's, which it doesn't mention, are 3.7v.
Am I making sense? I figured you guys would be able to help me out here.
Thanks,
- Joe
Thanks,
- Joe
