knutestoner
- Joined
- Feb 25, 2008
- Messages
- 3
I know I'm a "newbe" but please bear with me. I recieved this torch from the www.Fenix-store.com last Friday. Sometimes the switch does not activate the light in turbo or standard mode. For example, in turbo mode sometimes I'll have to press it up to 3 times for the light to turn on and then when it could either be the strobe or the correct 120 lumens. Then sometimes the light will flicker and be slightly dim in turbo mode. Once activated in standard mode it does seem to go the 3 power levels properly with a slight touch of the switch. I called the store today from work and was told I couldn't use rechargeables in this flashlight as that would void the warranty. I told him I was using Powerex 2700maH Ni-Mh rechargeable batteries. I came home and went to their website to check out the L1D Pemium Q5 specifications and it states that Ni-mh batteries are fine for this light. Maybe he misunderstood me or am I missing something? I'll be calling him back tomorrow. Anyone else have problems with this light? Thank you in advance.
