maxa beam
Banned
- Joined
- Feb 26, 2006
- Messages
- 420
For EDC. Title.
I can't believe it took seven posts to get the right answer! You guys are slipping.Buy both.
Mossy: While the Fenix is advertised to be like 135 lumens or something, it's no where near such. The 120 smokes it pretty easily.the arc is the better light out of what youve got it narrowed down to.
i wish someone would do a shootout of all the nice 1xcr123 EDC lights (120p, p2d-ce q5, PD-s, arc6) and i would put money on the fenix. yeah, it really is that good.
It will be more powerful than the NovaTac, but its beam pattern will almost certainly be much less diffused. Peter has said that he prefers a slightly throw oriented beam over a flood for an edc light.If the LS was more powerfull than the Novatac and had the same beam pattern...
Just to be clear (and nitpicky), maxa beam and I were talking about flood and you are actually talking about spill. Spill is the term for the area of the "flashlight beam anatomy" that is comprised of the unfocused part of the beam that surrounds the focused spot. Flood/floodiness refers to the characteristics of the beam, such as the width of the spill, the intensity difference between the spill and the spot, and the smoothness of the transition between the two. For example, a SF L2 is considered a floody light because it has a wide spill that is slightly less distinct from its spot than is considered typical. The NovaTac has a similar beam but would be considered slightly less floody since both its spot and spill are narrower (not necessarily narrow, but not remarkably wide) and the spot may also be slightly more defined (not much though). A Malkoff M60, on the other hand, is not a floody light, despite the fact that it has a larger spill than an L2. It's a thrower, but, as you kind of suggested, that doesn't mean its spill is bad...A good throw does not mean less, or bad, flood, nor that it will be bad for close-up work. In addition, if the flood is good, but the spot is too intense...
