EvilPaul2112
Hello all,
I recently was looking for someone to perform the resistance fix to my ROP HOLA "C" Mag switches...blah blah blah blah....I learned to mod them myself. Since then Ive done several for myself and several for others.
I have (2) NEW "C" Mag switches for the newer (c series) lights:
1. Added .100 solder wick(braided wire) to the positive spring assembly, soldering the spring cup and the lower positive tab, allowing full movement of the spring.
2. By-passed the stock ground and soldered a direct ground to the negitive tower, also using the .100 solder wick. The cam action still operates and allows for focusing.
3. Added a nice build-up of solder on the positive battery tab for better connections, especially with flat-tab batteries.
4. Treated the remaining internal contacts with "Pro Gold".
This mod is simple, but effective. The resistance is reduced DRAMATICALLY.
$28.00 each. shipped CONUS.
Send a PM if interested. The first "Ill take it" wins. PayPal preferred.
Thanks,
PAUL
Milwaukee, WI 53215
Thanks,
PAUL
Milwaukee, WI 53215
