BigBluefish
- Joined
- Jan 25, 2008
- Messages
- 1,461
I was wondering if anyone familiar with these lights (or with the M3/LM33 or M3/T10) can tell me if the M3 is significantly brighter than the LM33, both in 1 x CR123a configuration, and/or significantly less bright than the T10 (in it's pre-Q5 version)?
Confusing enough?
I'd just about decided on an Olight T10, as sort of the 'do everything' 1 x CR123a light, but thought I should ask you guys first.
The T10's good ponts seem to be a low-low w/very long runtime, high-high, (the reviews I've read say, yes, it is bright) and usefull levels in between. I can ignore strobe and SOS. Possible bad point - the UI seems pretty complex, which makes me wonder about long-term durability. I won't be doing any rough duty with it, but it seems more complicatd than necessary for my needs, and over time, something more to break.
I looked again at the M3. Good points are low-low, with good runtime (but not the 20 and 40 hours of the T10 on its lowest modes), the ability to use 1 x AA and 2 x AA (I'm a sucker for these combo lights) and (I hope) a high-high, meaning to me at least 75 lumens out the front. Also, simple reverse clicky, or forward clicky - pick one. It also seems to be pretty rugged, which is a bonus, because I'm a klutz.
I had initially thought I'd like an LM33, but the runtimes are much less than either the M3 or T10, the low isn' t that low, and it seems from what I've read the high isn't that high - meaning its nowhere near the 90 lumens Lumapower claims ( and probably not even close to 75 lumens out the front.) It seems such a nice little light though...
So....is the M3 brighter than the LM33, or are they about the same on 'high'? Is the M3 almost as bright as the older (Q2?) T10 or does the T10 blow it away?
Basically, I think I'd prefer the M3 if it is not significantly dimmer on 'high' than the Olight T10, because I like the simpler UI, and the ability to also use AAs. The low-low is there, as is good runtime. If it isn't going to give me 75 lumens or more, than I think I'd have to go with the T10, and live with the overly complicated (IMHO) UI. Now, if someone tells me the LM33 on 'high' is close to the T10, well then I'll be back to thinking about the LM33, except for those comparatively short runtimes....
Confusing enough?
