Monkeyboab
Finally got the battery adaptors to finish this mod for my work and im really happy with the result. Id set out to make a light for use at work with an output of maybe 60 lumens to match the streamlight survivor. I needed to use this host to match in with the lights used in my work. I made one with a single ssc which was very bright then decided to go for this. I had to modify the switch as it was only a push contact switch and once id hollowed out the head it had to be removed. I fitted the small slide switch under the original switch cover to try and keep it looking as much like the original as possible. Then I took Dx's 3 cree module and filed off the edges to make it fit. Its running off 6 nimh aa cells. Its very bright makes a l2d look like a candle
Looking forward to trying it out in the dark tonight and then at work.
Thanks Rob
Thanks Rob
