radu1976
Among others I have 2 TIROS INOVAs : T5 and T3.
T5 throws about the same like T3, maybe the output is 10-15% more.
I do not get why the T5 - using 3CR123 and having about 3hrs runtime, so 60min/battery - is more expensive , about $20 more than its little brother T3 - that is using 2 CR123 to have a flat output for about 2hr20 min, so about 70min/battery -.
T5 is by FAR longer 9' comparative to 6' and less economical ...
As I have read some opinions about the latest versions of T3 and T5 ...same ideea : both using 3 CR123 , about the same brightness and runtime.
Then, somebody to explain
me why is T5 more pricey :shrug: Maybe because it can used as a stick for autodefense
More material, thicker aluminium tube ?
