ARC mania
I am thinking about doing a small run of multi function Extreme Micro modules. This would be a simple drop in that you would simply replace with the existing module. This should make the Extreme Micro the smallest, regulated multi function CR2 powered light here on CPF. The functions will be: low = 20ma, medium = 150ma, high = 400ma, warning beacon, strobe and SOS. The LED used will be rated between 70 to 80 lumens per watt and extremely bright for not using a reflector. If there is interest, the bad part is that I may have to do a pre-pay in order to make this a reality. The modules will be machined here in Japan by a local machine shop that has promised me a two week lead time. Please post here or send me a PM if this interests you as a Extreme Micro owner.
ARC mania
ARC mania
