all things return to a state of enthropy
, some day your lithium-ion battery will be dirt again
the chemicals of most rechargable batteries will eventually become less vibrant when parked and athropy takes over.
I find that the voltage depression which can seem like the much talked about memory effect is relative to the self discharge charachteristics of the chemicals used to make the battery.
sooo
the li-ion has the least problem with voltage depressions from uncycled chemicals. it has less problems because it stays in its powered state better.
any device that your continually using, randomly charging , shouldnt be able to display any specific location that a voltage depression magically appears as noticable ("memory effect").
WTF , ok in engrish, use it or lose it, if you discharge the li-ion cells down to thier within spec low, then immediataly recharge it, once every 6 Months, that would be More than sufficient. the rest of the time, any topping off will work just fine.
then add to that, the li-ion cell will live a bit longer if it isnt 100% charged all the time, so also dont worry about charging it to 100% all the time. especially for small battery devices like cell phones and PDAs which will charge a li-ion to a very high spec sometimes to gain capacity.
so for example, when we get a new fresh (protected) cell in, we will cycle it 2 times, IN USE, meaning just use the device till it reads low battery, recharge it immediataly, then every 6-12 months do the same thing once. the rest of the time, we just USE it, and charge it fully if the NEED for a full charge will exist, and ignore it fully when i know it is charged enough.
this could also bring up 50-50% pulse charging, which can do a reviving of old cells, and have a cell last longer, but that is a bit more complex and lesser known.
all of that would be WRONG totally, if you discharge the battery TO FAR, or Leave it discharged to far, as the li-ion cells will die completly when discharged to low. so if you depleate the cell to low battery indication complete shut off, then it would be good to recharge it, not leave it there for days on end. (cell phones and pdas Continue to use power after shutoff, to maintain memory)
if there was some perfect location, it would be to somehow have the battery at 50% all of the time, and that is about as practical as having 1/2 the battery in it to begin with
as far as trickle charging, most li-ion charging alogrythms end at a set voltage, completly different charging, than ni-?? charging. they terminate at a set voltage and stop charging altogether, or can possibly just keep that set voltage up (easy to do with little self discharge).
that is completly different than the topping alogrythm used for ni-?? or even a float for a lead acid, because it can sit on the charger for days, and not put any more power into the battery.
so the only concideration for "leaving it on charge" endlessly is , that they battery will live a bit longer if its "stored" at a slightly lower state (<100%).
so just like everyone has already been doing, you can mostly just use the thing any way you want to, and it will do what it is intended to do. and the more normal your use is, the more it will normally act the way they intended it to normally. Because normally people get low in battery every 6-12 months without any effort, and they use normal chargers that keep it within spec, and they normally wouldnt leave it drained to nothin, and normally wouldnt have it 100% charged.
so it couldnt be easier
just use it normal, then ignore the rest of my post
None of the above applies to SERIES cells, like say Laptop batteries, which could have much more issues with a deep discharge , cause there is more than one battery there, charging in series (balance issues and all). And if using unprotected cells, the user would have to stay within specs. cells and pdas usually have protected cells in them.
