Wrong! The DBS V2 uses the 2SM pill just fine. In fact here is a web link from the Dereelight webpage where they sell that EXACT setup.The OP wants a 2 CR123 light. Most Deerelight pills have a max input of 4.2v(includes all the digital pills). You can't use the 2SM(max input 6.0v) pill with the DBS V2...
Actually I'm not. Your link shows the DBS V1. Do you have a V2 with a 2SM pill? I have both the V1 and V2 along with a 3SD, DI, and 2SM. The 2SM will not work properly with the V2 because the V2 is shorter. They took the length out of the head area, which is what you use to twist, to get the 2 levels.Wrong! The DBS V2 uses the 2SM pill just fine. In fact here is a web link from the Dereelight webpage where they sell that EXACT setup.
http://www.dereelight.com/dbs2sm.htm
from this post http://www.cpfmarketplace.com/mp/showpost.php?p=2110622&postcount=38same reflector as V1, it's shorter due to no 2SM option.
This should help:What kind of burn time are we talking about for the Dereelight DBS with 2X CR123A?
Hi Wade,
1SM-1 input to 6.0v.
1SM-2 input to 16v.
