mdocod
If I see some interest I may go ahead and do a "run" of these. I've built a few prototypes in various forms for myself and have had pretty good luck so far. Utilizing a Judco 14V 10A (rated) switch, a hunk of delrin rod, some various pieces of copper sheet, screws, solder, etc, and viola!
The only "work" involved with the installation is removing the stock mag switch, then scrapping some anodizing from the inside of the mag body from either side of the switch opening (flat head screwdriver and about 1 minute of scraping is all it takes), then slide this switch up into place, and tighten down the socket set screw just below the switch button, that forces a pair of rods out the side of the assembly, which pushes the copper strips against the side of the mag body to complete the electrical connection and holds the switch assembly firmly in place. Drop the short rod into the switch hole, reinstall the rubber cover, and it's basically ready to rock, leave the mag head in place, install MR-16 through the bezel, plug it in, press into place, install bezel with O-ring and lens if necessary.
The ceramic socket is rated 750W, The switch 14V 10A, so far I'm pushing ~20V@~5A ~100W(18AA driving a 12V 50W "spot" with axial filament.) It's a beautiful wall of semi-focused smooth light and makes for an easy mod with cheap replacement bulbs available at the local hardware store. (The 2000 hour bulbs can usually handle rested cells that aren't high performers, 6000 hour bulbs might handle fresh off the charger a little better or nicer cells, I've blown a few with eneloops by getting too anxious and not waiting for the cells to cool down enough There are a large number of MR-16s out there that would be suitable for mag modifications... Like the 64634, and 64627.
edit in: Forgot to mention, this is a reverse clicky with very solid tactile and audible actuation.
I'll just convert this into a sales thread if I decide to make a run
oh.. almost forgot.. I figure price would be under $30 including shipping.
Thanks for looking!
Eric
Thanks for looking!
Eric
